Best free help desk software
Asked By 130 points N/A Posted on -
I need help regarding the help desk ticket software. As I need a software for the remote connection and I want a secure connection for that. Can you tell me which software I should use and from where should I download that. And I need to configure that software or not.
Answered By 0 points N/A #185208
Yes, there are many software you can use for the desk ticket software as you want the free software for that then there are also many for that the best one that I will recommend that is Spicework. It is easier and it will configure the setting automatically and it is easy to use. Just giving you the download link clink on that and download it and install it and it will do the configuration automatically and your work will be done. Below is the link for that.
Click Here TO Download
Click on the download now button
Just download it from the link and remaining it will configure automatically.
Answered By 10 points N/A #185209
Now, internet being at our palms and becoming a part of our life, We tend to do everything on it. It makes a hectic job easy for us. We can do anything simply and in no time.
One software for Helpdesk is ITIL.
It is a good software. It can resolve ticket 2x faster with good response, self serve, suggest solutions.
It provides complete help desk automation. Do whatever you want to, ITIL will handle the routines.
Combines with the tools you are already using.
Exports data anywhere anytime.
