Hi ladies and gentlemen,
I have a Computer Network set up at my office, and now, I need the Best Free Network Management Software that can help in managing the network for efficient work.
Best Free Network Management Software. How To Use For My Workplace?
For managing a network, you can download Nagios from https://www.nagios.org/downloads/.Â
 It is a tool that keeps an eye on the critical systems and services that run your system. It provides features like Handling of Events, Reporting, and Alerting.
It has a Monitoring Engine that makes it easy for the user to manage the network in a better way.
There is a version, known as Nagios XI that can be downloaded if one does not want to take the pain of downloading and configuring Nagios. Nagios XI is pre-configured and ready to use. Nagios XI is the best to work in small environments.
