Greetings,
I want to ask about the best free VPN for a beginner to start with, one that is easy to understand. I want to secure my connections at the place where I live. I am not willing to invest anything so I want one that is free, simple to use and simple to operate. Any suggestion?
Best free VPN for a beginner to use
Hi Michael,
The best free VPN software for the beginner is 'HotSpot Shield'.
Download the software from the HotSpot Shield Official Website.
The benefits of using the HotSpot Shield software are as follows:
1) It protects your IP address and you can surf on the web efficiently
2) It enables WiFi security to prevent hackers from accessing the personal information
3) It protects the device from malware and malicious sites
4) Secure your data, online shopping with the HTTPS encryption
5) It provides Data compression for iPhone and Android
6) You can set up your network administrator to access favorite content on the web
Here is one of the best options you can try in order to assure your protection: OkayFreedom.
OkayFreedom is a free and easy to use VPN. It will enable you to set your private server with ease and will encrypt any data you send over, as well as hiding what you do online to whoever could ever be concerned.
Assuming you’re on an open network, OkayFreedom will still make sure you’re safe and protected, so there’s nothing to worry about.
There are three versions of OkayFreedom. You must choose the basic installation as that’s the free one – rest assured – you have the same level of protection as the premium one and you can still enjoy 500 mb monthly.
