Best freeware driver updater for Windows PC
Hi. I just want to ask if there is freeware that can detect drivers on my computer that need to be updated so that I will not spend more time searching for driver updates in the internet. Can you give me any suggestions? Where can I download freeware driver update software for Windows? Thanks.
Answered By 10 points N/A #168208
The solution to your problem is Device Doctor. The Application scans your computer for hardware to see and check if there is any update or new driver available for your computer hardware. The best thing is that it also detect the hardware which is not identified in your window device manager. Its very simple and easy to use. All you have to do just click on Begin scan for your hardware and fetches and update the correct device driver for your hardware.
Click on Device Doctor to visit the page and download the software.
