Best freeware to recover data from a corrupted memory card?
The only way to make your camera work functionally is to have the driver if your using desktop.
We cannot actually give you the driver of the exact kind of camera or laptop you are using. This devices can be search on the BROWSER that i usually used.
Please try to search on www.google.com and type or search what kind and brand of item you got.
If you have a laptop then its going to be a big headache.
But theres a way on it to recover the device.
Go to Control Panel+System and Security+Backup and Restore.
You can shortcut it also by typing in the start up search menu as shown below:
This will lead you to a shortcut in control panel.
Try to restore the system.
I hope the site or link that i gave to you will help you with your desktop
And if your using laptop, i do hope also this SYSTEM RESTORE will recover your lost device in your system.
IF non of this work.
You can BUY a new CAMERA on it. This can be used either in desktop or laptop.
Hello Thnxbye.
You want freeware to recover files huh? Here are 2 tools that I can suggest:
How can you perform memory card recovery, if you imprudently delete your card or format it?
This unhappy thing always happens, say, when you go out with your family and take some precious photos with digital camera, but without transferring to the computer, some other members of your family carelessly delete the photos or format your memory card and there is no way to restore them.
The best freeware to recover data from a corrupted memory card is the Memory Card Data Recovery Software because of its ability to restore and retrieve missing or deleted files and folders from the memory card flash media. You have to undelete files in the memory card recovery software and the data can be simplified flash drive recovery process.
If it does not work try this one, DDR Professional Recovery Software, or try this NTFS Data Recovery Software and lastly you can help yourself to recover your corrupted data by trying this software, Memory Card Data Recovery Software. Try to download that software from the internet.
Notifications
