Best Freeware Registry Cleaner Software for PC
I have been using total uninstall as a freeware installation monitor, are there other freeware installation monitors that can clean all the registry better than the one have been using?
I use and recommend CCleaner which is a freeware with complete set of features and also have a very simple interface.
For your review, some features are listed below:
Hope this answers your question.
A registry cleaner is used to remove unwanted entries. There are plenty of freeware cleaners available on the web.
This is the best cleaner which i would suggest. Some other cleaners are: Jetclean, Easy cleaner, power tools lite.
Hi Adamswhitley
Along with aforementioned solutions also pay a visit this Techyv post too to get more information about your question.
