Best Hard Drive Wiping Software To Erase To Data From Disc Safely.
Hello folks,
I have lots of unused data and applications stored on my Hard Drive. I want to remove all that data without damaging my Hard Disc. I need an expert suggestion on the Best Hard Drive Wiping Software.
Answered By 220 points N/A #170463
All you need is a Data Destruction Software to wipe out all the data that is stored on your hard disk. You can download DBAN which is the short form for Darik’s Boot and Nuke.
It is the best Data Destruction Software available. It is available in ISO format so you can burn it to a CD or a Pen Drive and boot the PC from it. It has a Menu-Based Interface that is very easy to use. It is an Open Source Tool and can work with any Operating System.
You can download it from https://www.lifewire.com/dban-dariks-boot-and-nuke-review-2619130.
