sammy noel
50 points
Posted on - 08/23/2012
I have Mac OS X Mountain Lion and was wondering if someone knows any high end video editing software for mac?
Currently I’m using Adobe Premium Pro CS 5 on Windows 7, so tell me other software besides this one.
Any kind of help would be appreciated.
Best high end video editing software for Mac?
Hello Sammy,
Some of the best high end video editing software you can use for Mac include the following:
iMovie
This is a consumer-level movie editing software that you can get as part of the iLife bundle of media tools. It has got professional touches for instance frame stabilization for smoother movie playback, it has got drag and drop editing as well as transitions that are easy to configure , and its special effects are very simple for headache-free movie editing.
Adobe Premiere Pro
This is a software that has been around for many years. One of its strongest selling points apart from the rock-solid editing is the tight integration it has with other software packages in the Adobe Creative Suite, for instance Adobe After Effects. It has been claimed to have one of the fastest HD video importing around, and it as well supports importing video projects from Apple Final Cut Pro.
Carl
