Best High Quality ATI SD Card Reader
What is the best model for ati card reader? For I am having some confusion on what is the best one to buy and I just dropped by hear to ask your best suggestion for this matter. I need a high quality card reader for I have so many important sd cards files to be transferred.
Thank you.
Best Answer by CORDOBA Ferrer
Answered By 5 points N/A #173534
A card reader is a very simple tool/ device, it's just an adapter that can connect different types of memory cards to a computer so the brand or model isn't really that important. When you purchase one just show them the memory card type or types you are using because that's all that matters.
Answered By 0 points N/A #173535
Hi Rebecca,
It’s true that brand and model is not as important since it’s only an adapter to accommodate different types of memory card types however if there is one but on higher side of price is “Silverstone FP34” which is supposed to be faster than others and covers most formats.
Hope this helps.
Thanks
