Best java database report generator
Which is the best java database report generatorBIRT Project or Dynamic Reports? It’s the first time I’m integrating this program to assist me on my reports. Most important is the easiest in exporting to other document format and overall user-friendly. If you suggest other java reporting generator that would also be great!
Best Answer by George J Layton
Answered By 20 points N/A #141922
One of the best and leading Java Report GeneratorBIRT Projects or dynamic Reports is the Big Faceless. Big Faceless Java Reporting Tools gives some of the most advanced XML to PDF conversion and the most comprehensive and on the market. The trial version is very functional. It stamps "demo" in each page of the report and includes features of the PDF library it's built on, charts, tables, graphs, as well.
Answered By 0 points N/A #141923
A BIRT reporter designer can be used , this eclipse based designer set of plugins can be used to build reports quickly . the set comprises of data explorer  that organizes data sources and data questions also is layout view editor that provides drag and drop creation of the presentation portion  also is the  palette that contains the standard BIRT reports such as labels and table.
