isabross
Posted on - 04/01/2012
Hello.
I'm planning to engaged on java programming. I want to practice this programming language but i don't know which is better to work with. My friends recommended me Netbeans, BlueJ and Eclipse.
Which do you think is the better Java Programming software out of the three to start with?
Is there other software I could use.?
Best Java Programming Software to Practice
Hi there ,
It seems you need help in choosing the best IDE (Integrated development kit ) for programming in JAVA.
All professionals in java would suggest you eclipse and tell its the best IDE for java or any other languages.
But since you are a beginner i don't recommend you getting to the eclipse . I feel comfortable and very easy with the netbeans .
Try netbeans !! It will give you the great opportunity to learn faster and easier.
After you have learned somewhat then you can think of moving onto eclipse or any other only if you like.
Netbeans has a very good UI and a soft interface development environment. Make sure you download the latest software from the netbeans website.
