Best Kronos Version for Steinway Model B. Keyboard
I need your help. I want to use kronos patch for Steinway Model B. But which is the best for this? Please, tell me the version no which gives best sound.Â
Thanks
Thanks
For this i would recommend the KRONOS System Version 2.0.6 . It is very good, specially if you want quality sound. Also Kronos software version 2.0.6 supersedes all previous versions offering various improvements and resolutions to specific operational issues. I hope that you find this all helpful and get what you are looking for. You can see the kronos user manual here https://shop.korg.com/Services/Kronos_Sounds/v206_note_E1.pdf
Peter franklin
