Lauramendez
10 points
Posted on - 10/19/2011
Hello Everyone,
I am planning to buy a new laptop and I need an information of what laptop brand has the best specifications.
My old laptop is slow and have a very low memory.
I would like something that is fast, has a large memory and reliable.
Can you please suggest a laptop brand with the latest processor and latest video card for gaming?
I will use the laptop for games and software downloads/uploads. My budget is more or less US$800.
Thank you very much.
Lauramendez
lee hung
75 points
Best Laptop Brand and Specifications
Hi Laura,
Though different people have different tastes when it comes to laptop brands, I will suggest to you what I think is the best brand in my view. Personally I find HP to be the best laptop brand.
Since you intend to use it for gaming, ensure you get one that has memory of not less than 3 GB, Hard Disk Space of not less than 320 GB and processor speed of not less 3 GHZ.
The sellers of the computers know these things and it is up to you to make sure that they confirm to you the specifications lest they sell you a laptop that will end being slow.
Hope this helps.
Lee Hung.
Hello Laura,
Let me tell you there are many brands like Dell, HP, Toshiba, Samsung, acer, asus which can provide you the best specifications of the laptop.
But depending upon the performance and service Dell and HP laptops are leading the market.
Also your budget will be the important factor in determining nature of laptop i.e. high memory and video card.
Considering that you want to use laptop for gaming and software purpose Alienware proves to be the strongest among all the other brands.
If you can re-adjust your budget you can have these monster machines pawning other brands anytime:
Alienware M11X: ($899) :
Intel® Core™ i3 2357M (1.3GHz, 3MB Cache
11.6’ high def display
4GB DDR3 RAM
320 GB SATA HD
Nvidea Ge force GT 540M 1GB graphics card
Alienware M14X: ($1199):-
Intel® Core™ i5 2430M 2.4GHz
14” high def display
4GB DDR3 SDRAM
500 GB SATA HD
Nvidea Ge force GT555M 1.5GB video card
This killers pawn any machine in terms of performance you expect, so as far the gaming laptops are considered this two are best within you budgets .
But still if you want to look for options below 800$ check out the site
With your present budget of around $800 more or less the closest I get that is best for gaming would be Dell Alienware M14x which is priced at around $999.
Here are some of its specifications and features:
- Runs on third generation Intel® Core™ i7 processors
- Comes pre-installed with Microsoft Windows 7 Home Premium 64-bit
- Installed RAM can be upgraded up to 6 GB
- A Slot-Loading Dual Layer Blu-ray Reader can be optionally added
- Runs on NVIDIA GT 650M GPU with up to 2 GB RAM
- Measures 13.27 inches wide, 10.17 inches in diameter, and 1.49 inches in height
Dell Alienware M14x
Additionally, for those users who are looking for fast and slick computers, the Sony VAIO E Series 14P would also be a great choice. The Sony VAIO E Series 14P [SVE14A16FG] runs on a 2.1 GHz Ivy Bridge-based Intel Core i7-3612QM quad-core Hyper-Threading processor. You won’t say anything because this is an excellent computer when comes to performance.
Besides being a quad-core processor, it also features the Hyper-Threading capability which boosts the processing performance and is able to simultaneously handle eight software threads which is really perfect for extreme multi-tasking and multi-threading applications.
The unit comes with AMD Radeon HD 7670M video card with switching technology, 4 GB DDR3 SDRAM, and 750 GB 5400rpm hard drive.
This is priced at $1,499. For a much in-depth information, you may visit Sony VAIO E Series 14P (SVE14A16FG).
