petrosiago
10 points
Posted on - 10/30/2011
Given IBM, HP, DELL, and ACER laptops, which brand would you advice for a user who is interested in Durability (e. g lengthy warranty), Performance (e. g considerable speeds), Reliability (e. g good battery), and Cost (cheaper cost per unit)? Could there be other better options than the ones I listed? Please indicate the specific models if you've got any in mind.
Mark B
Best laptop brand/model for a non-gamer
It is up to you to select the best laptop of your choice, you have to take the pain of researching through all the models because there is a great variety of build type in any one brand. You cannot say which brand is better in general. I will give you guidelines on selecting a model.
You don't want a laptop for gaming therefore select a model with no video card and small screen length, RAM size between 2-4 GB, processor speed doesn't have to be above 2.0 GHz. It should have a high battery life for office works.
Bluetooth, WiFi and webcam are common features in most laptops so include it. One year is the popular warranty period for most laptops so there is not much choice there. Look for the cheapest laptop with all these features.
Considering all your needs like you told, warranty, Performance considerable speeds, Reliability good battery but you don’t mention in any scale like what you really need considering speed heavy speed like Intel Core i7, or normal like core 2 due. How much battery life you need like there are many kind of that like average is 3 to 4 hours on the other hand high as much as 8 hours.
As having the experience I recommended you to buy HP Compaq for low end user with configure like Intel Core i3 processor and 3 GHz ram like 2 GB or 3 GB video card like 512 MB to 1 GB, battery life like 4 hours. Compaq gives good service.
Abbyarc
For consumer who often tends to have a brand quality this would be a difficult question to answer. Since every computer has its uniqueness. In regards to your inquiry one best brand of laptop computer is Toshiba.
Considering its durability there is no other laptop can be compared to this one. Since you will not spill any liquid beverages and accidentally smash its screen, definitely it will take longer years of running.
Since most authoritative websites praised Toshiba for its reliability, one factor is that it is the second lowest failure rate and you wont hear anybody complain about Toshiba being over heat which commonly the main problem of every laptop computers.
So we end to the conclusion that we are compensated on what we pay for. Apple proved to be the editor's choice and the why it is top of the notch, which means it, is highly recommended by consumers.
Without arguing apple do have a long battery life, speedy ssd and not to mention about its impressive graphic performance. Every apple Mac provides standard software packages that will allows its users to tackle everything from small to bigger things.
Another laptop brand is Lenovo, for business type this would be most required laptop. It includes power manager which conserves its battery life and primarily it has rescue and recovery just in case you did not notice the battery just went down. Mostly likely user of this Mac has a good impression.
