Best live video overlay software
What live video overlay software is fast and best on mac mini? I listen that it is necessary to convert all videos to overlay format to watch.
There are several video overlay software on the net. You can try these software’s that can help you to edit professionally.
Hi Joan D Vogt,
The above mentioned softwares are best suited for the professional use. If you want to try out some free softwares, then you can try Debut Free Mac Video Recording Software which is available here: http://mac.softlandmark.com/multimedia/free/Debut_Free_Mac_Video_Recording_Software_Info.html. If are not a fan of professional video editing softwares as they are difficult to understand for the new users, then try Mac IIci with colorSpace II and colorSpace FX boards. It is capable of tracing a live video. Hope it helps.
I give you a couple of software which is easy to use; these might be suits for you.
video edit magic.
This software is user friendly and can edit videos very easily. You can do anything with your audio and video separately and independently using this application. Also you can capture videos using a webcam.
Avid Video Editor.
This application intended for non-linear edition of your videos. This is quite similar to Windows Movie Maker and Windows Live Movie Maker. So you can simply make and edit any videos as you like.
