My mobile phone yesterday fell from the table and its screen broke and it stopped working. When I contacted customer care they asked to replace it at high cost. Is it possible to repair the slightly broken screen instead of replacing? If possible, then where to get it repaired? Which is the best mobile from HTC in low budget?
Best Low Cost HTC Mobile Phone
There is no possibility in fixing a broken phone screen glass. You can buy a new glass for it, but it's not worth it because you would be better of with buying a new phone.
If you are asking for a low budget smartphone from HTC, i recommend one of these two models:
1. HTC Droid (119$) – 4 GB storage capacity (you can add a MicroSD card), it has 3G capability, a 8.0Mp camera, Bluetooth,  1.2 GHz dual-core Krait CPU, 1 GB RAM, the camera has an LED flash with face detection and geotagging, Full HD recording at 30 FPS, a 720 pixel front facing camera, Wi-Fi capability, GPS, NFC connectivity, Accelerometer, proximity sensor, a standard 3.5mm audio jack.
2. HTC One X (217$) – it features a 4.7 inch HD widescreen display with a 1280×720 pixel resolution, a 1.5 dual-core processor, a 8 MP with an LED flash and autofocus, zero shutter lag,  a 16 GB storage capacity, it features 4G connectivity, the battery capacity reaches 1800mAh, bluetooth, GPS, Wi-FI, NFC connectivity, a 3.5 mm audio jack, proximity sensor.
These are the best HTC phones that require a low budget for you to purchase. A phone like this will keep you more than 3 years if you take care of it.
