Dear Techyv Users,
I am using Dropbox & Google Drive. Please help me by suggesting the best Mac cloud encryption software, that will provide Highest Security for my files in the Cloud. Ensuring that the software is fast and easy encryption cloud software. Please suggest.
Thanks & Regards,
Merrill V Christman
Best Mac cloud encryption software
Hi Merrill,
The are many Mac Cloud encryption software listed below:
A) Boxcryptor
1) It is a free non commercial software that can be used with Mac OS
2) It allows the user to secure the data in any cloud storage like dropbox, Google drive, sky drive
3) It uses AES-256 standard to encrypt and protect files
4) In the unlimited versions, add an additional security layer by the filename encryption
5) Download the software from BoxCryptor official website
B) Viivo
1) It is a free software that can easily cloud file encryption services for dropbox
2) It is design for working with dropbox and can be used with devices like Mac
3) Download the free available software from Viivo official website
C) DataLocker
1) It is a great tool and does not require a technical ability to sync the dropbox files
2) It just needs the user to drag and drop the files that are to be encrypted and decrypted
3) It uses a 256 key bit for encryption processors and provides a high level of security to data
4) Download the free tool from DataLocker official website
D) CryptSync
1) It provides the functionality to manage two folders containing the same data
2) You can upload the data in the folder with password protected files
3) The modifications in either folder will be reflected in the second one
4) Download the software from CryptSync official website
