Hello Techyv Guys,
I would like to convert few TTC fonts to its corresponding TTF version in my Mac system. Please suggest me a best Mac TTC to TTF Converter that can be downloaded for free or get me a link towards any online convertor. Please do the needful.
Thanks in Advance,
Nancy
Best Mac TTC to TTF Converter
Hi Nancy,
You are looking for an online MAC TTF to TTF Convertor. I found an interesting website, very simple to use.
Here is the link,
Just select the file by clicking on "Choose file" and then choose the format you want to convert to; there are a variety from which you can choose.Finally click on "Convert".
Then wait for a few minutes until you obtain the converted Font to be downloaded.
Hello!
If you want to convert something just this one time, or in any case, if you consider you will not need the converter very often, you could use an online converter. This way, you don`t have to download and install anything and your issue will be easily and very fast solved. One of the free online converters is the one found on Appslick. You can find it in the link below and also use next time you need something like this.
Online Converter
Good luck!
