Micromax Mobile with Android platforms are really amazing because they relatively cheap,easy to use, stylish and trendy. Which Micromax Mobile model is your favorite at the moment and what are the top most selling models in India?
Best Micromax Mobile models in India
These are the best selling Micromax phones:-
1. A110 Canvas 2: – It is one of the best Micromax Android Smartphone which runs on Android 4.0 Ice Cream Sandwich. It comes with 12.5 cm multi-touch screen with resolution of 480 X 854 Pixels. It costs Rs 11490.
2. Micromax A87 Ninja 4:- It runs on Android 2.3.5 and comes with a 4 inch capacitive touchscreen with resolution of 480 X 800 Pixels. Its cost is Rs 5,689
3. Micromax Ninja 3 A57:- It runs on Android 2.3 and comes with 3.5 TFT capacitive touchscreen with resolution of 320 X 480 Pixels. Its cost is 4,749
You can check other Micromax mobiles here
Laz Zebbena
