Best mobile anti virus 2012 of Android
Hello, Guys! I am actually looking for mobile anti virus for my Android device. I am using HTC evo 4G. Please give me suggestion which is the best mobile anti virus 2012 of Android.
Hi there,
If you are looking for an anti-virus for you android device, you can go to your Google play store and download the anti-virus that will suit your phone or device. But if you want, you can go directly to this site and download the AVG anti-virus, AVG is good for you android phone. https://www.avg.com/en-ww/antivirus-for-android
Hope this helps.
Hi Matthew
You can also use the any one of the following antivirus software to protect your mobile from virus.
