Best mobile unit for Windows Phone 8?
Windows Phone 8 was just released yesterday. What is the best phone and the best time to buy to optimize this OS?
Hi Dallas,
Since the Windows Phone 8 now release, I could say that it is most likely like the Windows Phone 7 which some upgraded features. It is okay if you wanted to buy a new phone that fits the Windows Phone 8 but I could say just like the Windows Phone 7 it fits the Android Phone as well.Â
I would suggest that you buy a smartphone model under HTC or Samsung models that supports Windows Phone 8. You could also buy Nokia Lumia 900 it also fits for Windows Phone 8.
– Asis
There are many phones that run on Windows Phone 8 and one is the Nokia Lumia 1020. The Nokia Lumia 1020 is a 4G Smartphone operating on 2G, 3G, and 4G network bands using GSM, HSPA, and LTE technologies. It was unveiled to the public and released on July 2013 measuring 130.4 x 71.4 x 10.4 millimeters and weighing 158 grams.
It uses micro-SIM card. It has AMOLED capacitive touchscreen display with 16M colors at 768 x 1280 pixels screen resolution and protected with Corning Gorilla Glass 3 featuring PureMotion HD+ ClearBlack display. It runs on Microsoft Windows Phone 8 upgradable to Microsoft Windows Phone 8.1 powered by Qualcomm MSM8960 Snapdragon S4 Plus chipset, 1.5 GHz Dual-Core Krait processor, and Adreno 225 GPU.
It doesn’t support microSD. It runs on 2 GB RAM with 32 GB internal storage. The primary camera supports 41 megapixels featuring f/2.2, 26mm (wide), 1/1.5″, 1.12µm, OIS, AF, Carl Zeiss optics, Xenon & LED flash, and panorama. It supports 1080p video recording at 30 fps with 4x lossless digital zoom. The secondary camera supports 1.2 megapixels and 720p video recording at 30 fps.
It has 3.5-millimeter jack with Dolby Digital Plus audio enhancement, Dolby Headphone, and active noise cancellation with dedicated mic; Wi-Fi 802.11 a/b/g/n with dual-band, DLNA, and hotspot support; Bluetooth 4.0 with A2DP, EDR, and LE / aptX after WP8 Denim update; GPS with A-GPS and GLONASS support; NFC; stereo FM radio with RDS support; and microUSB 2.0. It has built-in accelerometer, gyro, proximity, compass, and barometer sensors.
It runs on non-removable BV-5XW Li-Ion 2000 mAh battery with standby time up to 384 hours on 3G and talk time up to 19 hours on 2G and 13 hours 20 minutes on 3G. It is available in yellow, black, white, and red colors.
