dave tuttle
60 points
Posted on - 12/06/2012
Our short film project is about the western movie couples of the early 1900's. Can you please suggest good movie editor software that greatly supports some  effects that closely resembles the feel of the early 1900's movies? The software is not necessarily free as long as it is of affordable price.
CTRL + Q to Enable/Disable GoPhoto.it
Best Movie Editor with Old Movie Effects
Hi Dave Tutlle,
There are a herd of movie editing softwares available in the market.Â
Some of the most used and ones with the best reviews areÂ
Adobe aftereffects
Adobe Premiere
Cyberlink powerdirector
Coreldraw videostudio
Sony Vegas studios
Each of these softwares provide a lot of filters and options that can be used for editing your aforementioned movie. However these effects or filters will not be directly available. You can search and download the same from your video editor of choice.
I would recommend Adobe aftereffects or Cyberlink Powerdirector.
Enjoy editing.
Powel Jedei
