Best Mp3 To Text Converter Online For Free
Which are the best Mp3 to text converter online which are available for free? Will the text file be transcribed perfectly? Will the audio quality make the difference?
There are many online converters, but the most that are used are Freemake.com, 360coverter.com, and speechpad.com. It can be done by YouTube also. The resulting file may require some editing manually though, as programmed transcription service is not always perfect and always require human input. The audio quality makes a difference as the clearer the audio, the more accurate the resulting text will be.
If you want to convert an audio recording in MP3 format into text and you want to do it online, I found two online services that offer this job. First online service you can try is MP3 to Text from Happy Scribe. You can use this to transcribe an audio recording in MP3 format into text.
The web app extracts the speech from your MP3 file in just few minutes and converts them into text in different languages like English, Spanish, French, and over 119 other languages and accents. You can try and sign up for the free trial and for their pricing, go to Pricing & plans. Another online service you can try is Audio to text from Bear File Converter.
