The Best Music On Hold Players
Where do I find the best music on hold players? I have decided on the music which I can play when a customer is on hold, now I need to know more about music on hold players which will play the required music.
There is one good player which I personally use in easyonHold.com. It is an .mp3 USB Music on hold playing device. It gives you 5 year warranty. You can load .mp3 files very easily. No software is required at all to use it. It comes with a built in monitor speaker. In case of a power failure, it restarts automatically. It also comes with a sturdy metal case and a 1 GB USB drive. Your music will keep playing over and over again. You will get it in 1day after you order onÂ
 https://easyonhold.com/on-hold-systems/mp3-player/
