The best network monitor software in the Market.
I am working in a private organization as Junior Network admin. My senior boss asked me to search the best network monitor software in the IT market. Anybody could put light on this?
I understand that your task is a little complicated and harder than it look because there are a lot of Network Monitoring Software around and just by looking in the web would not be enough. To make your task easier, I want to share with you a list and comparison of Network Monitoring Software in the market .This will help you know and compare all the different software's features.Refer to the attachment below. Good luck!
Hello Vivian,
Before you try finding network monitoring software, you must have a list of goals that you need the software to achieve. Top on the list should be the ability to discover network devices without much of a fuss.
The program should not tie you down to a particular manufacturer, this ensures that you are flexible with regard to software and other devices on the network, translating to a 90%-100% compatibility rate. With that said, take your time to review the following software:
1. Spiceworks: Winning the hearts and minds of IT pros and vendors worldwide
Have a good one.
