kwan jason
Posted on - 07/23/2016
Hi. How to convert JSON to XML online? Can it be done online? Also, what rules need to be followed during the process and what are the uses of the converter? Please let me know the details ASAP It will be very helpful. Thanks in advance.
The Best Online Tool For Conversion: Convert JSON To XML Online
Hi. Yes, there are online tools available to convert JSON to XML online. The rules followed during the process include-
1) Firstly, there is a default source element that is created
2) The array entries of JSON are converted to the XML elements one by one
3) The values of JSON are ten converted to the type of text items
4) Characters are kept XML escaped
In the online tool, there are two options of either uploading the content of the file in the box provided or typing in the URL of the file. Then, the name of the source (root) element is asked for. Name of elements of the array entries of JSON is required. Indentation required in the XML output is asked for and also whether output needs to be in a new window or not.
The uses of the tool are as follows-
• Conversion from JSON to XML
• Easy to use as it allows you to load the file from your PC and start the conversion immediately
• Once the conversion gets completed, the file can also be shared or downloaded
Hope we helped.
