Best pacman dos box emulator for Mac?
Hi guys,I have played many dos based games using dos box for windows.Recently I have bought one Mac pc.I want to know whether the same pacman dos box emulator is applicable for Mac users also.Thanks.
Hi there Hollis,Â
If you're already using DosBox for windows then you wouldn't have any problem when you move to Mac. DosBox has its own app developed and compatible for mac users, Linux, fedora, etc.
Your DosBox windows may not work with your mac but downloading and installing the compatible app for your machine will make it work.
Here's the official website where you can download DosBox's Website
Hope this works for you.Â
Waall Mike
