Best PDF reader with PDF dictionary English iPad.
I have iPad 2 and was wondering if there is any PDF reader available for iPad with English Dictionary capabilities. Any kind of help regarding PDF dictionary English iPad would be appreciated.
You should try out Perfect Reader Pro. It's an awesome PDF reader with Dictionary and Wikipedia support. For Dictionary and Wikipedia you would need an internet connection:
There is also a free version of this application but it doesn't have all the features. Check it out:
Good luck!
The following are some of the PDF readers available for iPad with English Dictionary capabilities:
iAnnotate PDF
It is a highly versatile tool that has got a lot of features that can be used to improve your reading experience. When using it, you can be able to eave marks on pages as well as draw directly on them, you can set bookmarks and also view multiple documents in separate tabs,. You can even go ahead and customize the app’s interface to your likings. If you use Dropbox, this device has a service for it that lets you get your e-books from your Dropbox account.
iPDF Reader
It is the most lightweight PDF reader available, and it has got no impression of speedy operation as well as an easy to navigate interface. It has got an integrated PDF search engine.
Carl
