Trevor Jhon
40 points
Posted on - 11/17/2012
Hi to everyone,
I would like to make poster from different photos. I need a great and reliable photo editing software that will allow the user to put some effects from the photo. This is very important for me to get some tips from you guys about photo editing.
Thank you.
Best Photo Editing Software for Creating Posters
Hi there,
If you are looking for the best photo editing software or application, I would like to recommend you the Adobe PhotoShop cs5 or cs6. It really works for me. It has a lot of features that you can easily use for editing.
You can search on YouTube for tutorials. It helps a lot.
Hi Trevor Jhon,
The first program you should think to use is Photoshop. It has many features, tools, filters… for your creation. You can retouch your images; combine them; add some effects; add text… to make your poster.
Moreover, the structure of a Photoshop file is a combination of layers. That means you can reuse it someday in some ways.
Hope this helps
