Best Photo Editing Software For Mobile
I wanted to post some photos on my Instagram, is there any way to capture photo and edit it conveniently on my phone with easy to use editing app?
There are several apps that allow you to edit your photos on the go.
These are some of my picks, that doesn’t mean it is the best one around:
• Snap seed:
This app has a lot of feature like every other app and helps you to experiment on your photos with lots of customizable settings. There are also a lot of effects, stickers and color adjustment features which you can use.
• Picsart:
This is one of the popular apps on the list. Picsart has a lot of features like motion blurring effect, masking, and some awesome FX. At the first look, it feels confusing but it’s easy to use.
• Instagram:
You are probably confused, but yes, Instagram also has some masking and FX features that you can use. It’s one of the convenient one out these since you get to use only one app to edit and also upload your photo.
