I am in urgent need of a software for professional billing and invoicing that's compatible for Mac PC. I know there are numerous software available for professionals, but i would like an opinion from experts on which is the best. I would appreciate advice from you on professional bill invoices.
Thank you.
Best professional bill invoices software for Mac?
Hello Denise,
There are several professional billing and invoicing applications that are readily available in the market that will best suit your need either simple or complex variations. Here are among the few –
For simple, basic and free application there is Express Invoice downloadable at http://www.nchsoftware.com/invoice/index.html
On the Job 3 application a cost effective application at $39.95 that also comes with powerful feature with its easy to use feature. You may download and/or purchase it from here: http://stuntsoftware.com/onthejob/
Good luck!
Yes, there are numerous billing and invoice software available for Mac, but in my opinion, iBiz from iggsoftware is the best. It's now at version 4. It supports many features such as billable hours, project management and most important creating invoices. It comes with templates to help you. Application can also integrate with iBank and add expenses to the invoice too. It costs $39.99. Get it at http://www.iggsoftware.com/ibiz/index.php
