Best program to scan docs contrast online on web.
I want to scan contrast of some documents and wondering what is the best program to scan docs contrast online on web? If someone knows then any kind of help would be appreciated.
Dear Lark,
You might be interested in using this website to scan document content.
http://www.copyscape.com/
It works like a charm.
Also, if you are dealing with correction issues indocuments and you would like to scan for that then you need to go to the following link:
https://www.grammarly.com/?q=grammar
It is a very extensively used web tool.
I hope you get the best out of this.
Kumay Edwards
Hi, Lark. I am clearly understanding your demand scan contrast. ScanR is one of the best programs for the purpose. You can get an experience using it. Think it will be much comfortable for you. It’s service is similar to Qipit. The trial subscription gives you only one upload and fax but the premium account need only 499$/month or 2999$/year. Its feature OCR (optical character recognition), a faintly better designed border and sharing capacity.
On the other hand the cool feature for the ScanR is that you can use it to convert document pictures that were obtained using you cell phone camera to a properly formatted document. Most importantly it is very useful for things like page captures from library books and lecture notes.
