Hello everybody,
What is all about best fast startup software? Is there a software that helps your operating system start up processing? I got a problem with my three months old windows 7 starter operating system when it comes to starting up or booting up, it is slowing down. So I better ask your opinion about this.
Thanks and have a nice day.
Best Quick Startup Software for Windows 7 PC
On the computer startup you need to stop unnecessary programs to be started which might cause the computer startup process to slow down. Follow the below steps.
Type run and Press enter in startup menu.
Type MSCONFIG on the next appearing window.
Now you will see the below screen. Go to the Startup Tab.
It shows you all the programs that Startup with the computer startup. You can uncheck the unnecessary programs and press OK.
Hi Young!
The reason why your personal computer is slowing down is because of the files and programs accumulating in your hard disk drive from the time you have installed your Operating System. It is normal for PCs to slow down after a period of time. Another possibility is the presence of a virus or malware that takes up some of your memory, creating other background processes in the system.
There is no startup software that will help your machine load faster. All you can do is clean your PC. Do a whole scan, defragment your hard disk drive, edit the startup list of programs by entering "msconfig" in Run, uninstall applications you don’t use, and delete useless files in your Downloads and My Documents folder.
