Best recommended drivers for laptops
Hi, everybody!
I want to improve my laptop's utility.
I guess downloading the best drivers would help me make use of my laptop more efficiently.
Do you know where I could possibly find the best drivers that would fit my laptop?
My laptop is part of the Sony Vaio S Series.
Please help me with this.
Thanks a lot!
Best Answer by Lopez Berardi
Answered By 0 points N/A #181520
1. Check the model of your laptop. It can be found either on a sticker next to the touch pad or on the laptop's underside.
2. Go to this link.
3. Input the model name in the space provided.
4. Click "Find Support". You should see the support page for your laptop.
5. Click the "Downloads" tab.
6. The drivers that you need can be found under "Preinstalled Drivers and Utilities". Choose the ones that match your current operating system.
Answered By 5 points N/A #181521
Hope you are doing fine. Nice piece of gadget you have.
Well, your question is a bit ambiguous because for one, you have not stated the specific model of the machine you are using.
But if you follow this URL it will lead you to a site that you will choose the model of your system and also get to see the software that your machine supports.
Answered By 590495 points N/A #328676
If you are using a laptop and you want to improve its performance, I guess you need first to make sure that all drivers are installed and updated. For laptops and branded desktop computers, you can always download the drivers from the manufacturer’s website. See the following list of computer manufacturers:
If your laptop is Sony, click the “Drivers and Software updates for Sony products” link to visit the support page. Enter the laptop’s serial number or model number in the search field then click to search. You can find the serial number or model number printed on the sticker located on the side or bottom of your device.
