Best Reporting Tools for Java Environment
I'm a newbie in here and I was wondering if you can help me.
I'm developing a software using Netbeans and the database I'm using is MySQL. The web applications. My development is finished 50% and I'm going to create some reports generated from the web applications, but I don't know what kind of reporting tools are suitable for it. Some of my friends are suggesting me to use i-Report, while the others are suggesting me to use Crystal Reports.
When I was developing a desktop application, I always use Crystal Report 8.5. But now after I'm developed web applications, I have no idea if I can still use Crystal Reports 8.5. I don't know if the Crystal Reports are suitable for Java Environment since, I think it was intended for a .Net programming.
I know there are many best reporting tools out there and wondering if you're in my place, what kind of reporting tools that you're going to use. For i-Report, I've tried using it but I cannot get more satisfaction results I guess my mindset still in Crystal Reports. So sometimes I try to applied it in i-Report.
Please help me find the best reporting tools that works great in Java Environment.
Stan
