Best results gps log analyzer software
Hi guys,
Is it possible that some gps whether its on mobile or installed in car can be log? What are the best gps log analyzer software that has satisfactory result?
Hi guys,
Hi John Griesham.
I think you can use skydemone, ATOM GSP, or GSP tracking software. You will get the results that you want with this software. For more information and a user guide, just visit their web pages.
Skydemon : http://www.skydemon.aero/plan/
GSP Tracking: http://www.topgpstracking.info/Â Â
ATOM GSP: http://www.obviousidea.com/?from=pad_atomgps
Thanks,
Maxwell Mark
Hi John,
I would suggest the following software for your search.
While I researched for your requirement I found a top recommendation for this product. You can definitely hit it for a try and see how it performs.
https://sourceforge.net/projects/viking/
It’s open source software so you also don’t need to be bothered about its license. It’s free for all.
We can import, plot and create tracks and waypoints and other GPS movement per your requirement.
Hope this helps.
Thanks
Baker
