Best Samsung Android phone out in the market
Can some please tell me what is the best Samsung Android phone that is available now in the market?
Considering all the specifications and features of the phone and disregarding the price.
Hey Dear!
There are many Samsung Android phones in the market which start from a low rang to high range. The best Samsung Android phone in my opinion is Samsung l9100G Galaxy S II. This phone is totally awesome with 4.3 inches LCD. The internal memory of this phone is 16 GB and have 1 GB RAM. You can use memory card up to 32 GB in this phone.
The primary camera of the phone is of 8 Mega Pixels with LED flash and secondary camera is 2 Mega Pixels. The Android version of this phone is 2.3.4 (Gingerbread). The phone has Dual-Core 1.2 GHZ processor.
It also has GPU PowerVR SGX540.
This Samsung Phone is equipped with all the latest technology.
I will recommend you Samsung L9100G Galaxy S II.
No comparison!
Thanks
If you want to learn about the latest Samsung Android phone, the Samsung Galaxy Note7 is the latest for this year. The Samsung Galaxy Note7 Smartphone is a 4G device operating on 2G, 3G, and 4G network bands using GSM, HSPA, and LTE technologies. It was unveiled in August 2016 and is expected to be released in September 2, 2016.
It measures 153.5 x 73.9 x 7.9 millimeters and weighs 169 grams. It is built with Corning Gorilla Glass 5 back panel and will be available in single SIM and dual SIM (dual standby) that uses nano-SIM card with the following features:
It has Super AMOLED capacitive touchscreen display with 16M colors at 1440 x 2560 pixels screen resolution. It supports multi-touch and protected by Corning Gorilla Glass 5 with Always-on display and TouchWiz UI support.
It runs on Android 6.0.1 Marshmallow with planned upgrade to Android 7.0 Nougat powered by Exynos 8890 Octa chipset, Quad Core 2.3 GHz Mongoose plus Quad Core 1.6 GHz Cortex-A53 processors, and Mali-T880 MP12 GPU. It supports microSD expandable up to 256 GB. It runs on 4 GB RAM with 64 GB internal storage.
The primary camera supports 12 megapixels with f/1.7, 26mm, phase detection autofocus, LED flash, and OIS. The primary camera features touch focus, face and smile detection, 1/2.5" sensor size, 1.4 µm pixel size, geo-tagging, simultaneous 4K video and 9MP image recording, auto HDR, and panorama.
The primary camera can record video in 2160p at 30 fps, 1080p at 60 fps, and 720p at 240 fps with HDR and dual video rec. The secondary camera supports 5 megapixels with f/1.7, 22mm, dual video call, and Auto HDR support.
It has 3.5-millimeter jack with 24-bit/192kHz audio and Active noise cancellation with dedicated mic support; Wi-Fi 802.11 a/b/g/n/ac with dual-band, Wi-Fi Direct, and hotspot support; Bluetooth 4.2 with A2DP, EDR, and LE support; GPS with A-GPS, GLONASS, BDS, and GALILEO support; NFC; and USB 3.1 with type-C 1.0 reversible connector support. It doesn’t support stereo FM radio.
It has built-in gyro, proximity, iris scanner, compass, barometer, fingerprint, SpO2, heart rate, and accelerometer sensors. The pre-installed web browser supports HTML5. Java is not supported. It runs on non-removable Li-Po 3500 mAh battery. It will be available in blue coral, gold platinum, silver titanium, and black onyx colors. It is expected to be around 850 Euros.
