Good afternoon all, recently I installed security software for the phone, iPhone "Trust Call" it's just amazing software, simply it provide security from the beginning to end of the call , now I have two questions , is that possible to use this software with Nokia devices, another thing
Is that possible that 100% of our calls secured or the call records go somewhere after all.
The best security software for the phone.
Hi there,
TrustCall is currently available on  Iphone, Blackberry and Android phones. If your nokia device runs on Android OS then than should work.
Yes, your calls will be 100% secured. TrustCall uses validated encryption and provides a unqique key with no key exchange taking place while on call and that prevents from intereption.
You won't need a public key since you have a trustchip attached in your phone that encrypts the message.
Hope this answers your questions.
Thanks,
Nathan
