Best sites for dvd crown firmware updates
I want updates for my crown DVD firmware, what is the best site for get free updates for DVD firmware? Which site is reliable and better to download? any one suggest me some sites.
Hello Jackson,
I guess you can just try updating the DVD firmware directly from your computer. Do the following:
You will need to ensure that you have connection to the internet.
Nicke baker
Hello Jackson whiter
Hope that my message finds you well.
To get the latest update for DVD firmware Please Download the update from the below link:
http://www.softpedia.com/get/System/System-Miscellaneous/DVD-Firmware-Update-Utility.shtml
You can also Check this Link its also a NEC DVD Firmware Updates and FAQs:
https://support.necam.com/
Hope this solution will help you and please let me know if you need anything else.
Kind regards,
