Hello, members! I am using Smartphone from last 6 months. Actually, I am confused to choose the best Smartphone sync PST software. I know there are many free and premium software are available. But, which one is the best? Please help me to choose.
Best Smartphone sync PST software
Choosing the best software is based on personal taste. Â Every piece of software has something the others don't have. Â If you can't decide which software to use, then maybe you should consider some online tools which will help you to sync your data. Â For example, Dropbox is a great for this. Â It will enable you to do fast and easy syncing across all your devices. Â I hope I helped. Â Regards.
Mobile Sync Pro is a good software that will help you to sync your files.It is available for Android, Windows, iOS and blackberry. It backup all your data in regular interval and has features like anti-theft. You can set the connectivity feature like 3G, 2G, Wi-Fi etc to backup your data. You can check more details here: http://www.download82.com/download/mobile/mobile-sync-pro/
There are lots of software that can help you sync files between your computer and your Smartphone which are ease of use and provides rich features. Most Smartphones have their own syncing software  but here is the Top 7 Sync Apps listed below.
1. Dropbox – Is one of the Top 5 Business Apps for Smartphone. To sync, Install a "My Dropbox" Folder on your (PC, Linux or Mac) computer to place the files you want to sync, do the same to another computer and all other is automatically synced to your mobile.Â
2. SugarSync – It offers  5GB of free storage "Magic Briefcase" and it allows you to select additional folders. It has more mobile apps, However it does not support Linux.
3. LiveMesh – Its has "Live remote Desktop" a unique remote access. It offers more storage space.Â
4. MobileMe –  Is technically more of online backup or storage app for file are automatically updated on each device you have. It has iPad & iPhone locator and remote wipe services.
5.GoodSync – It synchronized directly without  between removable storage devices, computer without storing the data online. It has a feature-rich pro where you can try all sorts of syncing settings.
6. SyncToy – Unlike Goodsync it is Free but it only functions on Window systems.Â
7. SyncBack – It offers more features than the freeware version, file compression, advance customization, free, no space limits.
