Best Software to Backup Hard Disk
What is the best software to use on copying data from one hard disk to another hard disk?
I need to copy the whole system of my main hard disk to a 2nd hard disk. I am running a Windows Server 2003 for my data entry, and I am told to keep a back up of my main hard disk in case it will crash.
Answered By 20 points N/A #103070
Hey Conan,
Well it is important for every person to make a backup of hard disk to get all the data back in case of one hard disk crashes.
There are many softwares in the market that makes the backup of the hard disk.
For example ACRONIS, CASPERXP, NORTON GHOST.
In my opinion I would recommend you best and the fastest software that is NORTON GHOST.
You just have to attach the new drive to the old drive Via IDE cable and just run the program. It's result is amazingly fast. It depends on the size of hard drive and data that how much time will it take to create a complete backup of the hard disk.
