mubashir
Posted on - 07/26/2016
I was wondering for a while about how to send a large video file via email since it provides limited size for pictures and video sharing. Is there any software that can compress a video file for email?
R. Billy
Best Software To Compress A Video File For Email!
Yes, there is. The best software I have known for a long time and which helped me out very much for sharing large video files through emails is Avidemux.
Using Avidemux, one can easily compress all video file types and Choose another one of your choices. You can also set a custom size for Your video. It is as follows:
Open the software, click on the file and then open. Choose your video File and corresponding codec type. Then, tap the Configure button and Pick suitable options of your choice. Now, Go to Tools, then Calculator and set the custom settings. Now, save your compressed file after the processing has been done.
