Best software for make booklet
Hi expert, I need best software for my booklet. Is there specific software to make a booklet? If you know please send the download link. And send some helping tutorial explanations for how to use that software, Special features, Main advantages and disadvantages
Best Answer by Bernard L Jefferson
Answered By 0 points N/A #188821
You can now create your booklet foe Mac. Its easy to use but you have to follow some important instructions. It has adds an export command which allows you to convert any document into PDF for printing. You will get amazing features using this booklet software. Now create your own books with easy steps. I would recommend you two links which will be useful to learn more and you can also download this booklet software from the following links. I am sure you will fix this issue.
https://www.macupdate.com/app/mac/21068/create-booklet
http://download.cnet.com/Create-Booklet/3000-2088_4-86349.html
Answered By 65 points N/A #188822
Hi Kyle,
Shellbook 1.2 is great for beginners. You can easily communicate with your ideas. You can easily and quickly make a book by using this software. This software is the easiest way to create and print your book. This is worth $34.95. You can have a free trial before deciding about getting the software.
