The Best Sony Xperia Phone
What is the best phone in the Sony Xperia phone series? I just saw some of Sony's new phones like the Xperia P and S. What is the best phone among the bunch of Xperia?
It depends on your needs. If you want more than ordinary phone, I suggest you to choose Xperia P. This one is newer than Xperia S, so expect more features for this one. But if you are going to compare their specs some are better in Xperia P and some are better in Xperia S. So you need to look for specification which fit your needs.
Xperia S- https://www.gsmarena.com/sony_xperia_s-4369.php
XperiaP- https://www.gsmarena.com/sony_xperia_p-4436.php
So in the end, still depends on your capacity and needs. But if your question is all about better in performance, the best performance is the latest one which can give you latest functionalities regarding latest technology.
I am keeping my eyes on Sony's newest Xperia Sola. This is the first smartphone that has the floating touch capability. It allows the users to interact with their phones without touching the screen since the capacitive touch screen of Sola can register the user's finger up to 20mm above the screen. The specifications are as follows:
Processor: 1 GHz dual-core ST-Ericsson NovaThor U8500 that uses Symmetric Multi-Processing dual-core technology.
ARM Mali 400 GPU
5MP Camera
Internal Memory: 8GB with microSD slot
OS: Android 2.3 Gingerbread and will be upgraded to Android 4.0 Ice Cream Sandwich
Support for NFC
Connectivity: HSPA Cat10, Bluetooth, Native USB Tethering, USB 2.0
And also, the 3.7" mineral glass and scratch resistant display is powered by Mobile BRAVIA with xLOUD for audio. Available in colors black, white and red.
Notifications
