Best Speakers for Android Phones with Durability and PowerProof
I am thinking of buying new speaker for my Android phone. Is Pure Voca compatible with my phone? Does it support answering options for incoming calls? How much is it? What are the buttons available for functionality and features? Does it support Bluetooth connection? Does it support USB connection? What are the ports available? Is it battery operated device? If battery-operated how long can I use it before it turns off? What are the materials used for this speaker? Is it shock proof? I’m going to use it for outdoor activity, is it waterproof?
Answered By 0 points N/A #173122
Hello Janet!
The Sony SRS-X5 is a multimedia speaker that reiterates and redefines the technological advancements of NFC and Bluetooth technology.
It provides 2.1 channels that comprises a subwoofer and 2 front speakers. You can connect it with Bluetooth connectivity. The price will cost you $163.60.It has the hands-free calls capability, one-touch listening via NFC device. Can be connected with your android phones and iPhone. It has the transmission range of 33 feet or 10 meters. The output power is normally 20 watts. Battery hours can hold up to eight (8) hours. Supports Stereo mini-jack input and USB ports. You can recharge it also with your USB cord. It comes with AC adaptor for recharging.
