Best technology among GSM, WALL and 4G
Newer mobile technologies are confusing. Should I stick to GSM, should I cross over to WILL, or should I hold on for 4G?
Yes, it really is. With the constant evolution of today’s technology, you’ll really get confused on what to use, how to use it, and what it is for. The Global System for Mobile Communications [GSM, originally Grouped Special Mobile] is the standard type of digital cellular networks which is set and developed by the European Telecommunications Standards Institute [ETSI] and is also known as the second generation network [2G]. This is the kind of network used during the early days of mobile communications.
Since these days the availability of mobile broadband modem USB dongle is very common and if you’ll be sticking to GSM as your network then you’ll only be wasting a lot of money. Because GSM is generally intended for mobile phones and will make internet browsing very poor if you’ll be using it with a mobile broadband modem USB dongle. The GSM was expanded over time which is now known as the GPRS [General Packet Radio Services], and then followed by EDGE [Enhanced Data rates for GSM Evolution] which is also referred to as EGPRS. It is later improved to what now known as 3G which is developed by 3GPP.
