I bought a HTC Innovation last night. Guys if you can suggest me a website where i can download for the themes htc innovation photo viewer application maybe. I found several but it cost way too expensive. If there are sites that offers free kindly message me so that I can start downloading. Thanks in advance!
Best themes htc innovation photo viewer or gallery
Hi Lawrence,
I cannot understand what did you want download? Theme downloader or photo viewer?
If you need photo viewer software then you need to go to the subsequent URL.
http://htc.mobile.brothersoft.com/htc-touch-photo-viewer.html
Just go there, give your phone model and download the software for free.
You have to search on Google for downloading themes.
Mobile HTC has many themes, programs and all backgrounds will find what you want in this link:
http://gallery.mobile9.com/c/htc-themes/1/
After going to the link you will find the models of HTC mobile Choose your model of existing models or enter the model of your mobile in the search box, then select what you want from the themes or backgrounds and click on download button, save the theme on your computer.
Hi there user:
A bunch of a theme that are free to download on-line, that’s the special, they’re free. But most contains virus which can be danger to your unit. Just a matter of concern in case you still want to pursue or experiment, make sure you scan it with anti-virus first.
But here I can give you links I think you or we can trust. https://themes.htc.com
Thanks for your query.
