Best tool for active directory bulk export import
I want to know about bulk export import to active directory. Please name the best tool for doing active directory bulk export and import.
Hi, Sherrydlongo!
The best tool that I can suggest for you to use with the bulk importing and exporting to active directories would be Dovetones software's Active Directory Tools, The AD Toolset Bundle. It has 7 tools for one software. Check this out at this link: http://dovestones.com/
If you somehow changed your mind in purchasing a program, you may also try doing this step-by-step. I will provide you with a link that will guide you in doing so. Here you go: https://technet.microsoft.com/en-us/library/bb727091.aspx
Good luck!
Notifications
