Best upgradation software bb offline
During upgrading software of blackberry, any phone call or message can stop upgrading. What software will be beneficial to upgrade bb offline?
Here are the steps to upgrade your Blackberry Smartphone’s operating system doing it offline or without having an active subscription or BIS. Before proceeding on upgrading the device, you should download the upgrade software first from Blackberry site. I searched the site for possible operating system upgrade versions, visit BlackBerry — Search — BlackBerry OS for the results and just download the one applicable for your device. Or simply visit BlackBerry — Update Software for the exact upgrade page.
You should also backup your phone’s entire data if you need to preserve or restore the files or important files after the operating system upgrade. Uninstall all programs related to RIM including Desktop Manager, and make sure nothing left related to it in your program files folder and in common files [Program FilesCommon FilesResearch In Motion] then restart Windows. For the rest of the instructions, you may visit < @ALAASDK />| a self closed web Geek, blogging about JavaScript and any web platform related technologies. — How to upgrade (install) Blackberry OS without having active subscription.
Notifications
