Which of the media players in recent times you recommend as the best in terms of user friendly and it being able to play all files? What are the advance features of this preferred software program as well as what makes it special from all other media players' features? Thank you.
points
The best user friendly media player in recent times
Media players are bread and butter of any PC. If any PC is without any media files and players with it, it becomes dull. There are many media players online and all of them aren’t for all.
User-friendly means less trouble consuming the application. There are tons of such players.
The best media player in my eye is Media Player Classic. It’s small, user-friendly and easy to use. Without lots of functions, it’s quite awesome.
KMPlayer is also a good media player with rich library. It also supports user-friendly UI, making you feel cool headed.
VLC Media Player should be the best choice for simplicity and complexity at the same time. If you want simple UI with advanced features, VLC should be your choice.
